is it possible to make 450rwhp without doing heads?
Headers
Good exhaust
FAST intake
Throttle body
electric water pump
Good tune up (Plugs & Wires)
Damn good TUNE !!!
Might need injectors
Good fuel pump !!!
gears
lower control arms
pan hard bar
tunnel mount bar
That should put u on your way lol
If i were you i wouldnt be so concerned about hp , use the track times and hp to figure things out . I dont trust dynos much except for before and afters , they vary too much .
110mph is good for a LOW 12 second pass if the mph you already achieved isn't artificially inflated from ridiculous tire spin.
With the right cam, you'll pick up enough power that given a real 60' (not the 2.3 I'm guessing you cut now, more like a 1.7-1.8) you'll be able to run 11.7-11.9. I've seen a 12.0 with a 110 mph trap from a car that was optimized for the 1/4 mile...but a 12.2-12.3 @110 is more realistic. Upgrade from there and hook it up.
With the mods in my sig, I make 419/382 on a mustang dyno. Stock 241 heads never been pulled off the car ans Stock LS6 intake never pulled of the car
Hi,your build is probably 325/340 rwh. We all want big numbers on the dyno. It cost $$$$$ to run 11.0 without bottle feeding. If your vehicle is nice as you quote on your question??????? Drive and enjoy.... Make people think you are 11.0
and yield not to temptation. My car looks stealth but never goes to the track.
Good luck and have a blessed weekend.......jim
