How to set lifter preload?
Old Feb 18, 2004 | 06:35 AM
Steve Burger's Avatar
LS1TECH Sponsor
Default How to set lifter preload?
Just did the H/C on my car and from the Dyno graph it was suggested that I check the preload on the Comp R lifters. Sooo...
How do I do that and if I need shims where can I get them? Is there a tool that will let me know that I have the suggested .002 preload? I hope this is just not a shot in the dark but that there is a way to measure.
Also are there adjustable rocker arms out yet that don't require machining the pushrod holes?
Thanks for any info.
Old Feb 18, 2004 | 06:39 AM
Country Boy's Avatar
Senior Member
Best bet is to get the adjustable rocker arms. With shims, youll get sorta close, but not right.
Old Feb 21, 2004 | 09:45 AM
LS1TECH Sponsor
Ttttt
Old Feb 21, 2004 | 10:49 AM
JF WS6's Avatar
Originally Posted by Steve Burger
Ttttt
JMX's LS1howto.com has some info about how to shim a set of Yella Terra's on his rocker install page....
Old Feb 21, 2004 | 03:14 PM
DanZ28's Avatar
You can measure accurately with a dial indicater and a magnetic stand. .002" is not much, maybe an 1/8th of a turn on the rocker bolt from "0" lash...
Dan
Old Feb 21, 2004 | 03:38 PM
LS1TECH Sponsor
Thanks for the link and the help. I have a few questions. So let's make sure I understand the how to article first. I need to get to zero lash by hand tightening the bolt with no rachet frist. At this point the pushrod should spin a little. After that I use the rachet to hand tighten and it should be no more than 1/16 to 1/4 turn. If more than that I need to shim.
Question #1 What is hand tight? This seems to be a very subjective term.
Question #2 If I need shims where do I get them and what size?
Question #3 Will using a touque wrench to get 22 lb/ft increase preload?
Question #4 Comp R lifters need .002 - .004 preload right?
Thanks.
Old Feb 22, 2004 | 02:30 PM
lsx24's Avatar
FWIW I was watching HP TV yesterday, and they were installing the valvetrain on an old chevy big block I believe. They used a rachet to tighten the lifter slowly and gradually, while spinning the pushrod with their other hand. When they could no longer spin the pushrod, they gave it another 1/2 turn and said woohoo. Not sure how accurate this is or if it would not be the same for a more modern application.
Old Feb 22, 2004 | 02:35 PM
LS1TECH Sponsor
Saw that but on a flat tappet cam not sure how critical lifter preload is. Thanks.
Old Feb 22, 2004 | 02:38 PM
2xLS1's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/141665-explane-lifter-preload-why-how-i-do.html
Old Feb 22, 2004 | 02:49 PM
David Plum's Avatar
Determine current preload subtract the diff. you need to come out of lifter buy sheet metal , cooper at sheet metal supplier remove rockers trace stand cut and drill place under stand
