Explane lifter preload and why and how I do it ....
thanks
https://ls1tech.com/forums/generation-iii-internal-engine/140252-how-set-lifter-preload.html
One suggest looking at an article on Yella Terra instal off of:
www.ls1howto.com
It was helpful but prompted a fe other questions.
That's all folks.
Some poeple do it diferently but I like the TDC method, because there is no chance of the valves dropping.
Becareful with this though. If you have installed new lifters, the finger tight method won't work. Finger tighten them untill the back (pushrod) side of the rocker starts to dip. Check the pushrod is still slightly loose, and then start your sequence from there.
To the original poster, all these methods are for using aftermarket adjustable rocker arms. The only way to adjust lifter preload with the stock rocker arms is to either put a shim between the rocker arm pedistal and head, or take material off the rocker arm pedistal. To answer your original question of what preload is, hydraulic lifters have an internal piston inside the body of the lifter that has a range of travel. under operating conditions, this piston is supported by oil pressure. Preload is the amount the piston is depressed in it's bore by the pushrod when the valve is closed and the lifter is on the base circle of the cam. Think of it as a starting point for the lifter piston with no oil pressure supporting it. I hope that's clear
If you're using stock rocker arms this is the way I check the preload:
Put some whiteout(typing correction fluid) on the part of the pushrod that is just at the pushrod hole in the head(maybe a one inch long strip of whiteout).
Now put the PR in the hole and just sitting on the lifter top. Take a black sharpie and mark a line on the whiteout stripe on the PR right at the PR hole in the head.
Now put on the rocker and completely tighten to torque spec.
Wait about 2 minutes(for the lifter to bleed down) and make another mark on the whiteout.
Now unbolt the rocker arm, remove the PR and measure the space between the two marks. That is your lifter preload.
I believe ideally you want just a little preload maybe .03-.06. You can go to .125 if you want.
Shorter or longer pushrods are the best way to achieve proper preload IMO. I have used pedestal shims but they're not the best way. When GM went to the smaller base circle cams in the ZO6 engine they used longer PR's.
However since most of us are doing heads and cam and the heads are milled and the cam base circles are generally smaller, we usually will need a shorter PR. Nine times out of ten you'll be fine with a 7.35 inch PR.
THE reason why I do that is both exhaust & intake valves are closed and the prods are equidistant, therefore same pressure on lifters, which enables me to duplicate the "FEEL" on a more consistant basis.
IMO I would change rockers to adjustables (Not to mention the faulty bearings that can occur with the stock ones)
