lq4 & lq9 help ??
Old Mar 26, 2011 | 01:32 AM
ram air camaro's Avatar
Default lq4 & lq9 help ??
does anybody have a list of all the vehicle years and models these engines came out of ?? im looking to find a good deal on an engine so i can slowely rebuild it for my 2k z28 ls-1 replacement ,, any help is apreciated even if its one models,,,,,,
Old Mar 26, 2011 | 01:40 AM
98silvermaro's Avatar
LQ9 is out of the silverado SS trucks and escalades
LQ4 wanna say it came out of the hummers... thats about all i know
I know my LQ9 is out of an 03 escalade and i think i the escaldes after the year 2000 are all LQ9's not 100 percent sure tho
but the 03 is a GEN III block... that i do know
Old Mar 26, 2011 | 07:22 AM
nobreaks254's Avatar
If your gonna rebuild it, your probably going to replace the pistons, right? Then it doesnt matter which one you get.
Old Mar 26, 2011 | 01:40 PM
yeah im going to stroke it to a 408, your right about being the same engine, so do u know if the ls1 intake manifold,headers,4l60e fit on that block ?
Old Mar 26, 2011 | 03:52 PM
Paul57's Avatar
I believe the LQ4 is very common in the 3/4 ton trucks (and vans too??). My LQ9 came out of an '05 Silverado SS (same motor as the Escalade). There is a certain letter or number in the VIN that will verify what it is. Maybe someone can share that info if they have it handy.
Old Mar 26, 2011 | 06:03 PM
speedtigger's Avatar
Old School Heavy
The LQ9s are Vin code "N". Escalades and Silverado SS only. All other LQ 6.0 motors are LQ4s.
Old Mar 26, 2011 | 07:19 PM
NemeSS's Avatar
Lq9 also come in the Denali
Thr burban version of gmc
Old Mar 26, 2011 | 07:27 PM
Thanks guys im writing all this info down so I can hunt a LQ block down, keep the info coming it very appreciated , thanks
Old Mar 26, 2011 | 07:44 PM
NemeSS's Avatar
All lqs are 24x FYI
Although some years came with 2 lengths bolts and earlier versions came with 3 lengths bolts
Old Mar 26, 2011 | 07:45 PM
NemeSS's Avatar
For the heads bolts
Old Mar 26, 2011 | 09:05 PM
where are you located? I have a 04 lq4 for sale.
Old Mar 27, 2011 | 01:24 AM
cen california
Old Mar 27, 2011 | 12:03 PM
@nemess what do u mean by 24x ?
Old Mar 27, 2011 | 12:51 PM
NemeSS's Avatar
24x is the crank reluctor wheel
Currently the ls engines use 2 reluctor wheels
Older use 24x
Newer use 58x
Depends on yrs and vehicles
Old Mar 27, 2011 | 04:02 PM
yes all that stuff will bolt on the that motor... its pretty much the exact same as a ls2... bolts right in and all the sensors and the same and everything... the only thing you wil have to do is use your f-body accessories and tap a 3rd bolt hole for the alternator... and of course its Iron
