Cams to pass emmissions
Old Feb 26, 2003 | 06:59 PM
Wile_E's Avatar
Default Cams to pass emmissions
I don't know much about what the numbers stand for in different cams. What I have learned from my search is that I need a cam with 114 lsa or higher to keep my car emmissions legal. Is this correct? What is the most aggresive cam I can run and stay legal?
Also, if you have a link to help educate me on what the numbers mean, post it up because I found nothing.
Old Feb 26, 2003 | 07:06 PM
Wile_E's Avatar
Default Re: Cams to pass emmissions
By the way, mods are in sig...just looking for a car to be a lion at the track and a kitten on the streets. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 26, 2003 | 07:40 PM
Ragtop 99's Avatar
Thunder Racing's 220/220 114 cam should pass emissions and maintain good drivability. You may be able to go a little bigger, but the 220 has a good track record of passing emissions and on a 114 LSA has decent street manners.
If you want a true kitten on the street a 212/218 114 using Comp XE lobes (~ .550 lift) will be very torquey and easily pass emissions.
Old Feb 26, 2003 | 07:52 PM
89ws6formula50's Avatar
If you want a true kitten on the street a 212/218 114 using Comp XE lobes (~ .550 lift) will be very torquey and easily pass emissions. [/QB][/QUOTE]
Sounds pretty close to the Hotcam
Old Feb 26, 2003 | 07:58 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
MTI B1 cam has also been proven to pass emissions by more than a couple members. It's a 221/221//.558/.558//114lsa.
I have this cam. Excellent street manners, while still having a nice beat at idle @800rpm <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 27, 2003 | 02:12 PM
Cal's Avatar
Cal
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 89ws6formula50:
[qb] If you want a true kitten on the street a 212/218 114 using Comp XE lobes (~ .550 lift) will be very torquey and easily pass emissions.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Sounds pretty close to the Hotcam </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not really, the Hot Cam and this one are at two opposite ends of the spectrum. The Hot Cam will give you a real nasty lope with it's 218/227 duration and 112 LSA. Not trying to put you down, I would just hate for someone to think these two behave alike.
<small>[ February 27, 2003, 02:18 PM: Message edited by: Cal ]</small>
