LS6 Cam, what's needed
Old Oct 4, 2011 | 03:37 PM
  #41
Mike Morris's Avatar
Did you change the springs? Usually pulls nice to 6500 or so.
Old Oct 4, 2011 | 08:06 PM
  #42
S8ER95Z's Avatar
Yeah I have the ls6 yellow springs on it. I believe either my oxygen sensors are bad or it's the tune.
Old Oct 4, 2011 | 09:31 PM
  #43
LS1121's Avatar
Just got mine back today. 98 LS1 used 799 heads 04 Z06 cam and LS6 intake, I think he said he used 7.35 or 7.375 push rods with LS7 lifters. I needed a tune for sure and got one and the car runs great. Don't think 7.4 are correct.
Old Oct 4, 2011 | 09:52 PM
  #44
S8ER95Z's Avatar
I have ls6 lifters on a 241 head.. My understanding is that ls7 lifters are taller and you would need a shorter pushrod length than ls1/ls6 lifters.
Let me know how that setup runs. I'm still on the fence with heads.. Not sure it's worth it yet.
Old Oct 5, 2011 | 12:09 AM
  #45
LS1121's Avatar
I had it on the highway tonight and i like it, no valve chatter. From what i've read the lifters LS7 are the GM replacement for all LS1 and LS6 engines. My guy told me to get the 7.4 but when he measured them they were too long. Now i have a set to put on ebay.
Old Oct 5, 2011 | 06:40 AM
  #46
S8ER95Z's Avatar
Yeah ls7s are THE replacement, they are direct drop in but people on ls1tech state the cup sits higher. I didn't mean they were physically taller than the other lifters.
Old Oct 5, 2011 | 06:53 AM
  #47
2nd Gen Fl 'bird's Avatar
Originally Posted by t/a98
Too bad we are the only two that get what you said....
Make that three.
Old Oct 5, 2011 | 08:18 AM
  #48
redbird555's Avatar
Good to hear it's running good but for most applications those are not the correct push rods. If you have stock heads with ls1 lifter 7.425 push rods are needed because the base circle on the cam is smaller than the ls1 cam... If you have real z06 heads, the valves are longer which allows you to use the same 7.4 push rods the car comes with stock.. In your case its special you used the "replacement" ls7 lifters which ideally need a .050 shorter pushrod and since you have 799 heads means they probably arent real ls6 heads with the hollow valves you cant take advantage of the longer valves. so actually the 7.375 pushrod makes sense in your case but not for most people
Old Oct 5, 2011 | 08:57 AM
  #49
LS1121's Avatar
I didn't think that the hollow valve stem valves came in ALL 243 heads, and from what I've read the 243 and the 799 are the same except for where they are manufactured. My heads are New and the valves are New Take Offs from an LS2 which makes them the correct valve for the head, I checked the part number. Also I said 04 Z06 cam.
Old Oct 7, 2011 | 08:01 AM
  #50
redbird555's Avatar
I didnt say all 243 heads had the valves only the ones that came on the ls6 I didn't say that the 799 wasn't the same head but was never put on an ls6 atleast I have never seen them. all I'm saying is that please don't tell people that a 7.375 pr will work for them because people using your exact setup with the stock ls1 lifters WILL take 7.425 because the ls1 lifter are shorter and the standard valves are shorter. My motor has the stock 7.4s in it because I have factory ls6 243s with the hollow valves and an 02 z06 cam.... Btw 04 z06 really doesn't matter the ls6 cam is the same from 02-06 01 is the only differen year so I'm not sure what you meant there
Old Oct 7, 2011 | 08:27 AM
  #51
S8ER95Z's Avatar
redbird555... any numbers from your setup? Just curious if the heads are worth the time/cost?
Old Oct 7, 2011 | 08:41 AM
  #52
redbird555's Avatar
I'd say the heads are worth it mines 385 whp but I'm an auto I've watched m6 cars go 400 regularly and a tad over with a fast
Old Oct 7, 2011 | 11:21 AM
  #53
Jim85IROC's Avatar
Ls7 lifters are a little different height than your originals too, so you should measure your pushrod height.
Old Oct 7, 2011 | 04:55 PM
  #54
baxsom's Avatar
02+ LS6 had the different valves.
01 LS6 had solid length valves the same length as the LS1.
Old Oct 9, 2011 | 01:10 PM
  #55
HottLS1Z's Avatar
Great thread and info here. I'm doing a set of actual Z-06 243 Heads and the 02+ LS6 cam myself. Been there done that with the big cam big heads race car thing before as well, just looking for stock characteristics at this point. One thing I'm confused on is the lifters. I remember I bought some LS7 replacements years back when I did my stroker and they were identical to stock and I was able to use the same 7.4 chromoly pushrods I had from doing a cam only setup prior. Has there been any design change in the LS7 replacement lifters in recent years?
Old Oct 9, 2011 | 03:41 PM
  #56
redbird555's Avatar
If you want to get technical about it then yes they did but it 01 the cam was also different and had a larger base circle so the stock pr's were still used. When people talk about the ls6 generally they refer to the 02-05 motors which is what i was referring to because no one really bothers with the 01 ls6 parts.
No they havent changed the lifters are still within "spec" and will work but they are still a tad taller so the 7.4's are ok and the dealer would leave them but ideally to reduce valve noise you would need a shorter pushrod. There are some companies on ebay that still sell the original style ls1 lifter which is what i used so I didnt need to buy new pushrods.
