Need help with my turbo build Por Favor
I spun a bearing in my trans am and need it running asap. I am going to run it N/A for a few months as my DD and eventually get to the custom turbo kit and throw on the HY60 holset turbo I have.
I am going with the TSP kit most likely, 347 rotating assembly for $2400.
It includes Callies compstar crank, compstar rods, wiseco -32cc pistons and rings, clevite H chamfered main and rod bearings and fully balanced.
I am also getting ARP main studs, cam bearings, gasket/head gasket kit and a timing chain.
Will a new stock pump work or should I get a better oil pump for the ~800 hp im going to make?
What else do I need as far as the build for now? i figure my stock injectors and tune will work since its the same CI.
I am on a budget now and want to get it running for as cheap as possible and throw money at the top end later and do stuff i can do with out removing the motor again.
