L33 Engine Question
Old Apr 6, 2011 | 08:04 AM
Code Red's Avatar
Default L33 Engine Question
Wondering if anyone has thoughts on this.
Found a local L33 5.3
The L33 (VIN code "B") is an aluminum block version of the LM7, and was referred to as the Vortec 5300 HO in marketing materials. Power increased by 35 hp (26 kW), to 330 hp (250 kW), over the LM7, and torque was unchanged. It was only available on extended cab 4WD pickup trucks. Only 25% of trucks made in 2005 had the L33 engine.
it has 22k miles on it and no accessories but does have the harness but no cpu for $950.
Good buy?
I'm starting my search for a V8 for my 04 Colorado
Old Apr 6, 2011 | 08:10 AM
MIKE93SVT's Avatar
pretty good deeal if it's complete minus acc. especially for teh miles. you shouldn't have to worry about anything. but i can grab an lm7 any day of the week for 300 bucks or so. just depends on if you are wanting an aluminum block for the price. if you watch for an LH6 out of a trailblazer, envoy, etc. they aree the same, but have flat tops and 243 heads. i snagged one of those just for the heads a few weeks ago for 325. just pick your poison and do some searching
mike
edit: be aware, the LH6 has dod, but can easily be deleted and still save money since you'll get the 243 heads in the deal
Old Apr 6, 2011 | 08:13 AM
Code Red's Avatar
mike
Thanks for the reply. I'll check around for my options on those.
I'm trying to stay under 1500 for my initial engine buy and less miles lessens my chances of having to visit a machine shop.
I know my engine rebuild on my GTO's 400 ended being 5 grand since I ended up having to buy new heads for it but there were other factors with that engine build.
Old Apr 6, 2011 | 08:24 AM
Code Red's Avatar
Well looks like LH6s near me are over 2000 and the LM7s are generally over 1200-1700 and are listed as hybrid but are two under 1000 one for 950 with 70k miles and one for 450 but needs one head.
Old Apr 6, 2011 | 08:40 AM
Code Red's Avatar
Also do the L33s have a 24 tooth reluctor?
Old Apr 6, 2011 | 09:17 AM
MIKE93SVT's Avatar
l33 is 24
where are you looking for these motors? criagslsit, or car-part.com?
Code Red's Avatar
l33 is 24
car-part
Old Apr 6, 2011 | 11:33 AM
Code Red's Avatar
well decided I'm going to go look at the engine and probably take it home today since it has 22k miles, complete with harness and coil packs and accessories brackets (just no accessories) and its a 15 min drive from my house.
Old Dec 13, 2011 | 08:43 AM
OldBBody's Avatar
What did you end up getting Code Red?
Old Dec 13, 2011 | 08:53 AM
Code Red's Avatar
I picked that motor up and its sitting in my garage. I had a shop verify it was in good shape and I started cleaning it up and painting the block. I have a build thread for it on here I think
Old Dec 13, 2011 | 09:00 AM
Code Red's Avatar
https://ls1tech.com/forums/multimedi...-colorado.html
Old Dec 13, 2011 | 09:20 AM
OldBBody's Avatar
Excellent dude! I will go check it out!
Old Dec 13, 2011 | 09:26 AM
parks450's Avatar
If your interested I have a truck accessory drive for sale. Everything only has 300 miles on it. PM if your interested.
