putting the trex in first part of the week
Old Feb 19, 2004 | 05:03 PM
SMOKIN01TA's Avatar
Default putting the trex in first part of the week
well is time for a cam, im going to give the new trex cam from thunder a test. i think ill be the first to try out the new cam, im going to try to do a before and after on the dyno with only a cam change for those of you who wanted to see it on a second car with original factory everything in the motor with 43,000 miles on the clock. hopfully ill have up the dyno numbers end of next week and if all goes well ill try to go to the track that friday or saturday to get some time comparisons. wish me luck, im going to start stripping the cars interior tonight. im also going to get some 4.56's and 28" slick after the initial testing to see if i can get her into the 10's with a 3400 lb. weight.
btw, if you dont read parts wanted, i need some 15x10 prostars asap
Old Feb 19, 2004 | 07:14 PM
xQuickSilverx1's Avatar
how much is this cam, I have yet to see a price, and good luck
Old Feb 19, 2004 | 08:17 PM
SMOKIN01TA's Avatar
its on their web site. the cam is about 430 and the who package you need is like 850.
Old Feb 19, 2004 | 08:22 PM
Wesley SS's Avatar
Good luck man I'll give you a call if you need help and im hopin to do the cam too. We both have the same miles and same time so I would like to see what it does in a A4 with 4400 stall.
Old Feb 21, 2004 | 11:38 AM
WS666's Avatar
I will be using the T-Rex as soon as mine gets here.
What exactly all did you get with the "whole package"? I only bought the cam so far.
Old Feb 21, 2004 | 04:40 PM
SMOKIN01TA's Avatar
you will need new valve seals if you go with the crane duals. i also got the retainers, seats, pushrods and gasket kits.
Old Feb 21, 2004 | 05:30 PM
Charles Cyrus's Avatar
Good Luck! wish it was me
Old Feb 21, 2004 | 06:10 PM
SMOKIN01TA's Avatar
thanks man. ill post up before and after dynos and track times soon
maby even some sound clips
Old Feb 21, 2004 | 07:35 PM
Johnny5's Avatar
very interested in this as well.. good luck..
now let's get some dyno sheets and clips
Old Feb 21, 2004 | 09:45 PM
SMOKIN01TA's Avatar
ill be sure to post um up
Old Feb 21, 2004 | 10:26 PM
2001 Pewter WS6's Avatar
Restricted User
I will let you know...
Old Feb 21, 2004 | 10:44 PM
SMOKIN01TA's Avatar
good luck man. im hopin for your current times in sig when im done with a few changes.
Old Feb 22, 2004 | 03:17 PM
Restricted User
I ran that 10.98 before I had it tuned and before the 12 bolt w/ 4.11's. I gained 60hp from the tune plus I have recently added Kook's headers. I am expecting mid 10's the way it sits now. I am going to run it a few times with my current cam for a good base line then I will swap the cam to see what kind of gains I get... I will be adding a AS Ported LS6 intake and a matching 80mm Billet TB.
Old Feb 22, 2004 | 07:37 PM
SMOKIN01TA's Avatar
sound like another bad *** setup. have fun
im hoping with the addition of some 4.56 gears, 28" slicks and going from 3600 lbs to 3300 lbs.along with the 100rwhp gain from the cam i should get some 10.8's with some 1.4x 60's over my current 1.8 60'. time will tell all
just want to beat the current cam only record of 10.9x with a m6. and he only weighed 3000 lbs.
