Incorrect Pushrod Length
Old Apr 8, 2011 | 11:07 AM
the_merv's Avatar
Default Incorrect Pushrod Length
What are the signs of this..if they are too short or too long?
Old Apr 8, 2011 | 11:13 AM
kinglt-1's Avatar
If the pushrod is incorrect legnth, the rocker will not be center on the valve tip. take the rocker off, mark the tip of the valve with a sharpie, then install the rocker, rotate the engine a few times, unbolt the rocker and inspect the wipe pattern.
Old Apr 8, 2011 | 11:16 AM
the_merv's Avatar
Thanks..i'm just trying to check everything before I get the Engine completely back together.
I guess there is probably a specified pre-load aswell..and if it's too long then it would probably be noticeable.
Old Apr 8, 2011 | 11:24 AM
kinglt-1's Avatar
I think stock rockers are tq to 22ftlbs... not sure on aftermarket?
Old Apr 8, 2011 | 11:36 AM
kinglt-1's Avatar
http://www.gmhightechperformance.com.../photo_06.html
this writeup might help ya for aftermarket rockers.
nichoms's Avatar
I think preload, at least on the newer LS7 Lifters, is like 0.060" to 0.100" so there is a little wiggle room in there. I set my preload at 0.080"
With proper length and preload it should be reasonably quiet.
Pushrod length is easy to measure and pushrods are easy to replace so you might as well measure and make sure you've got the correct length.
And yes, the rocker arms require 22ft lbs
