need help! think i blew a hole in piston....
Old Apr 9, 2011 | 02:31 PM
SHibbY01WS6's Avatar
Default need help! think i blew a hole in piston....
so i just installed my N2o kit its a N.O.S plate and solenoids well i hit for the for time and every thing when great had a A.F.R of 13.0 13.1 (on a AEM UGOE wideband) really did move well when i hit it again a it went fine than shifted and had a bad miss so i stop and now the car has a miss all the time...the A.R.F is at 14-15.5 under normal driving but with a bad miss and im blowing smoke out the tail pipes...so i open the hood and found oil on the underside and along the intake but found the pcv tube was off the pcv valve...i i think i bunt a hole in my piston causing the smoke and the miss but im not to sure but i would like advice about if it is a shot piston do they make replacement stronger pistons for the stock bore? or should i build this bore this block? or look in to say L92 or something like that?
Oh the car it self is a 01 ws6 with a t56 i have it tuned with hp turner and the basic bolt on minus HEADS/CAM
so if you have and more info need ask...and thanks in advance to all who reply
Thanks Mike...
Old Apr 9, 2011 | 03:47 PM
motorsports601's Avatar
Did u change or retard ur timing? People run nitrous with stock pistons all the time. Buy a used piston and put it in the number 7 hole most likely to break. Check ur compression with compression guage start with #7 and I forget the one. Idk if 13.0 afr is safe on nitrous?
Old Apr 9, 2011 | 03:52 PM
Yes I retarded the timing...and I will do a compression test Monday when I go back to work but I u think that I should with the stock? ...thanks for the reply need all the advice possible
Mattsv8's Avatar
id tune rich for spray like low 12.s that way if timing dont retard the extra fuel can help with detonation
Old Apr 9, 2011 | 03:54 PM
that's what I was thinking I'm gonna do tune down and put a bigger fuel jetta but right now I just want to address the pistons and if I should go bigger and or stronger thank you so much for the reply
Old Apr 9, 2011 | 04:33 PM
I think if u want to go big on the shot yes go for pistons and rods. But if u just buy pistons ur gonna have to balance the rotatiing asembly and might as well do a rebuild. That's all gonn cost bucks. People run nitrous on stock pistons they're not the best but hold up with the right tune. Did u read the nitous forum on here maybe u should post this there too. Problably more answers on there..
Old Apr 9, 2011 | 05:27 PM
I will post there didn't even think about that .. thanks
Old Apr 11, 2011 | 04:09 PM
any more ideas fellas? comments/ideas/thoughts/suggestions...hell criticism really any thing cant hurt the situation thanks again for the replys
Old Apr 11, 2011 | 04:40 PM
35th camaro's Avatar
what size of shot did you spray, like 125 or 150hp, most likely #7, seen same thing hapen, dip stick come out of tube and spayed oil every were, burnt #7 and scored the cylinder.
Old Apr 11, 2011 | 07:44 PM
yea did u check it? If u don't have a compression guage use ur finger compared to the other cylinder if possible. R u driving it? I wouldn't drive it u could do more damage. I had a small miss before on my ls1 it was a broken rocker pedastal. I broke a piston on my supercharged 5.4 and it had bad blow by and smoked. Its prolly not what u want to hear. But if ur lucky u can just put a used piston in there cuz its already balanced to ur motor. If u want to swap pistons ur gonna have to balance everything pistons rods crank and its gonna be expensive.. here's a bump hopefully more people will give advice
Old Apr 11, 2011 | 08:18 PM
rotary1307cc's Avatar
You should know easily if you lost a piston just from blow-by
Old Apr 13, 2011 | 08:21 PM
OK guys...did alil diagnose the car to day... so first i check for spark and i i had spark all cyl....so i started pulling plugs 1.2.4.6.8 were looking good and 3.5.7 here black and oily as hell...started to do compression tests 1.2.4.6.7.8 were all between 195-210 psi...(7 really surpized me...i woulda swore that it was a bad one confused so that leaves 3 and 5 both of them where below 60psi ....i didnt do a leak down test cuz the heads are coming off now to assess the damage ....so thats what i got as of now it you guys want ill keep this updated along the way so let me know and if you have questions/commets/suggestions/thoughts/ post it up! could use all the input there is
Thanks
Mike
Old Apr 14, 2011 | 07:56 AM
redtan's Avatar
Were you monitoring knock at all while spraying? I have a feeling that your 13.0+ AFR at WOT on the juice is what did it. That's on the lean side for a N/A engine, so for a big shot it's dangerously lean.
My bet is a few melted pistons.
I've seen this on a friend's car (not LSX) where he was spraying but was monitoring the wrong knock retard in the tune and he was knocking like hell all along. Blew a huge chunk out of a piston.
