Noise after cam install (video)
Old Apr 10, 2011 | 05:09 PM
shane2390's Avatar
Default Noise after cam install (video)
Just finished up installed 226/234 on a 113 from EPS. Trick flow pushrods and dual springs. Thought Id post before i look into it. When I first started the car i had just a faint ticking sound, and once it was fully warmed up and after a drive around block (staying under 2k.) now it sounds like a Very loud sewing maching... Used loctitie on the rockers and rechecked the torque after a few revolutions. any ideas?
http://www.youtube.com/watch?v=WUNgoNBNNUk
Old Apr 10, 2011 | 05:22 PM
95LTXZ28's Avatar
Sounds like theres a rocker issue there. I know roller rockers add some sewig machine like sounds to an engine, but I can hear that noise over everything else.
Old Apr 10, 2011 | 05:32 PM
KevinR's Avatar
Maybe you got the wrong size pushrod?
Old Apr 10, 2011 | 05:35 PM
Always2Slow's Avatar
First of all what consisted of your build. What size pushrods did you use. Did you change lifters or oil pump during your build.
Old Apr 10, 2011 | 06:06 PM
farmington's Avatar
Sounds like an old hydraulic cammed car with loose rockers. I'd say you need longer pushrods. Or at least measure what you have and get a length checker to see what you need. Sounds like all of them are loose. That means no preload on the lifters. Should be corrected soon.
Old Apr 10, 2011 | 06:19 PM
shane2390's Avatar
Just did cam springs and retainers. I looked at the pushrods before installing but after reading some posts I forget what size. I guess ill pull the covers off at work tomo night if there's not too much work coming thru. Oil pressure is fine and it only did it after it fully warmed up. I've had a light ticking sound before the swap but it seemed like normal ls tick
Old Apr 10, 2011 | 08:24 PM
Paul 75 L82's Avatar
Read this thread.
https://ls1tech.com/forums/generatio...ip-inside.html
Old Apr 10, 2011 | 11:20 PM
uLs1a's Avatar
What size pushrods did you use? Before I put my EPS cam in I have TSP 7.400" hardened pushrods and Patrick G told me I needed to use 7.425"
Old Apr 11, 2011 | 12:03 AM
MattSapp95_T/A's Avatar
I am running an EPS cam and with my heads and block being stock Geoff told me to run 7.400 as long as I was running ls7 lifters and if I was running stock lifters to use 7.425
Matt
Old Apr 11, 2011 | 06:31 AM
gennex's Avatar
my car is doing the same thing, i was quiet, i refreshed the motor and had the valves cut, the thing clatters like crazy.
Old Apr 11, 2011 | 05:03 PM
Patrick G's Avatar
LS1 Tech Administrator
Often, the oil pump o-ring gets pinched or cut when reinstalling the pickup tube and your oil pressure will be lower than it should resulting in louder clatter as the oil gets warm and oil pressure drops further. See it all the time.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 11, 2011 | 05:26 PM
gennex's Avatar
i put in a new oring yesterday, same issue, it was the green oring and very tight to fit.
Old Apr 11, 2011 | 09:43 PM
SScamaro4's Avatar
Lifters might not be pumping up
Old Apr 11, 2011 | 09:46 PM
LS1aiden's Avatar
lol you got the wrong push rods length most likely! what size cam u got in there?
Old Apr 12, 2011 | 06:39 AM
gennex's Avatar
just took a straight edge to my valves and notices the intakes are longer than the exhaust valve, darn thing never had noise before so i dont see how the valve length cause it all the sudden. any ideas.
