Double roller timing chain clearance question
I spent about an hour and a half, with a die grinder and sanding disk, clearancing the inside of cover till it fit right. If others didn't have the issue I envy you. Next time I will go with LS2 chain.
1. high RPM's
2. aggressive cam lobe ramp rate
3. high spring pressures
