spring install help!
Old Apr 17, 2011 | 02:20 PM
schino's Avatar
Default spring install help!
im putting pac 1518's on 799/243 heads. i bought the springs from a member and it was the whole kit which when i got them had springs, seats, seals, locks. now the question is.. the stock seats are pressed in right? do i have to change them? the ID of the 1518's are bigger then the stock springs so if i dont add any seat and use the stock one the spring has a lot of movement. if anyone can help me id appreciate it. got the motor all torn down doing a cam swap
Old Apr 17, 2011 | 04:51 PM
schino's Avatar
I thought they were pressed but they aren't... Pulled the stock ones off put the pac one on but the seals I have fit on there loose... I'll do some searching but if anyone could shed some light I would appreciate it
Old Apr 18, 2011 | 03:57 AM
vettenuts's Avatar
The seals you are installing are used? That may be part of the issue if they are.
Old Apr 18, 2011 | 04:35 PM
schino's Avatar
got it all figured out now after doing some searching. thank ya for the help
Old Apr 18, 2011 | 11:39 PM
Mart00SS's Avatar
http://www.yellowbullet.com/forum/sh...eehive+springs
Post #7 has the locators that I used. I ran into the same problem and everyone said to just drop them on the stock locators but I wasnt comfortable with the amount of movement that those springs have on the stock locator. I used the Ferrea SL1080 locator with a new set of umbrella type valve stem seals.
