Which oil pump/chain combo?
Old Apr 17, 2011 | 02:37 PM
NastyNate65's Avatar
Default Which oil pump/chain combo?
Im probably going to use this Melling oil pump
http://texas-speed.com/shop/item.asp...=1095&catid=55
Ive heard a double roller timing chain is the best way to go, but it says you can only use a single roller with this pump. What pump/chain combos are you using? I want to replace mine before i put a cam in my car
Old Apr 17, 2011 | 03:05 PM
*02WS6TURK*'s Avatar
What are your cam specs? An LS2 timing set and a LS6 oil pump normally do the trick. That's what I'm running at the time.
mark21742's Avatar
Double roller chain with the Melling 10296 pump
Old Apr 17, 2011 | 08:21 PM
CranMaro99's Avatar
Can you just buy the LS2 timing chain for a direct replacement or do you have to buy the entire timing "set" w/ the gears and all?
Old Apr 17, 2011 | 08:27 PM
9911UZ28's Avatar
https://ls1tech.com/forums/generatio...t-fit-ls1.html
Old Apr 17, 2011 | 08:28 PM
LS1aiden's Avatar
i have this pump.
Old Apr 17, 2011 | 08:37 PM
cookba's Avatar
Yank has had a nice deal on the LS2 chain sets.
I have the C5R chain and the ported Melling pump. the C5R chain is overkill, or added insurance depending on how you look at it.
Old Apr 17, 2011 | 08:53 PM
theevette's Avatar
I went klatch ls6 pump and c5 r chain
Old Apr 17, 2011 | 09:03 PM
'02 WS6's Avatar
Ls2 timing kit from Yank and a ported LS6 pump suited mine just fine.
Old Apr 17, 2011 | 09:30 PM
JimMueller's Avatar
I went with the Katech ported oil pump on my last 3 motor builds. Used the C5R chain on the current LS3 build, but used the LS3 chain in the prior two builds.
Old Apr 17, 2011 | 09:40 PM
VandykeT/A's Avatar
I've got the TSP ported shimmed pump and just a LS2 chain. It keeps great pressure.
Old Apr 17, 2011 | 10:14 PM
itsslow98's Avatar
melling 10296 in both my ls1s, also both have ls2 chains.
