Need help finding some cam events
Old Feb 21, 2004 | 02:06 AM
Pat-Man's Avatar
Default Need help finding some cam events
Okay...I've got Desktop Dyno 2000 and I am trying to plug in some cam events. The problem is I did not degree the cam when I put it in, and I do not have the cam card. Is there any way to calculate the events with normal timing at .050 lift. The cam is a LPE GT-1 cam with these specs:
218/229 Duration .560/.560 lift and a 113 LSA
I wish I had a cam card because most of the events are listed on it ex: LCA, Intake centerline etc.
Thanks all...let me know if I'm pretty much screwed too.
Old Feb 21, 2004 | 07:18 PM
99 Black Bird T/A's Avatar
J-Rod & Cstaub posted formulas & links to calculate cam events but you will need to how much advance the cam had and how it was degreed in order to determine intake centerline. Some probably knows what advance is for that cam but I don't.
Here's a link to the formulas
https://ls1tech.com/forums/showpost....93&postcount=7
