Pushrod length checking questions
On the intake I got 1 1/2 till snug. It was probably a little bit more to get to 22ft lbs. I didn't have my torque wrench tonight.
We did this at least 1/2 a dozen times and got the same thing everytime.
Disregard the this part of the previous post as I had been partaking in the Bud Liteus' and forgot to put the 7.350 pushrod in. I got to thinking about it today and decided it was pretty much impossible to have 2 1/4 turns with a 7.35 pushrod. I'd have like 3.5 turns if that was the case with the 7.4
I put the 7.35 in on the exhaust side today and I get 1 1/4 turns snug, not torqued. I remembered the two being different now I know how.
One thing i think the LS7 lifters has is a bit more engineering. They "allow" more preload. (Also deeper cup) But what I actually think from the hours of **** I read on this, is that the LS7 lifters were designed to handle more rpms. Therefore, more pumping of the lifter will occur at higher rpm. I think they engineered more room for the pump up at higher RPM. I will be running at the intended RPM for these lifters. So I will only put in minimal preload. Therefore the room for pump up will be taller and safer for higher rpm use before they lock up tall from the pump and bend my rods. And yes. The Comps have different lifters with different preload requirements.
To recap w/ 7.35 push rods I have a little over 1 1/2 turns on the intake and a little over 1 1/4 turn on the exhaust. These are just snugged not torqued. Using hiltsy855 chart that still puts me in the .074-.093 range which is better where I'm at now.
Instead of trying to figure out how deep you are into the lifter by computing through the rocker ratio, go buy a couple of adjustable pushrods. They aren't that expensive and you can get an accurate measurement that way.
Ref:
https://ls1tech.com/forums/generatio...questions.html
Intake
7.300 3/4 turn
7.325 1 turn
7.350 1 1/4 turns
Exhaust
7.300 1 turn
7.325 1 1/4 turn
7.350 1 1/2 turns
I think I was over complicating the whole process before. After doing it this time and taking time to write my results down and understanding what they actually mean makes everything much easier.
Thanks to everyone who has taken the time to help me.
