Anyone running an EPS cam like or similiar to this one?
https://ls1tech.com/forums/general-l...p-running.html
this is untuned idle of my 230/234 .601/ .603 eps cam 111lsa
No need to bash 01ss-he just stated his opinion.
You can't spec too many diff custom cams to people tha are full boltons and the normal mostly street/ some track use. If he has good results with a certain grind then id hope he'd recommend it to others with similar mods/goals
Looks like I'm starting to strike a nerve of some of the millions of EPS cheerleader's squad.
My point is, the reason you are seeing these cams specs being spec'd similar or identical is because some cams just work well. Thats how cams like the TR224 became what they are today. With every new "which cam" thread pops up, you have the same dipshits cramming "custom EPS" down your throat. When actuality, you will be buying something thats already been spec'd before that we all know works. I guess saying its "custom" just makes you feel so warm and fuzzy huh?
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
My point is, the reason you are seeing these cams specs being spec'd similar or identical is because some cams just work well. Thats how cams like the TR224 became what they are today. With every new "which cam" thread pops up, you have the same dipshits cramming "custom EPS" down your throat. When actuality, you will be buying something thats already been spec'd before that we all know works. I guess saying its "custom" just makes you feel so warm and fuzzy huh?![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
ever popular TR224 back in the day and he and Pat G. worked closely with
Billy Godbold @ Comp to design a lobe profile around .600 lift,Bhive compatible
and minimize the ever hated sewing machine noise. If you understand how
lobe flanks affect valvetrain harmonics you'ld also know that it's not snake
oil sales we're talkin about here. I DARE you to call Geoff and spend 15 min.
asking questions...perhaps you might even upgrade that Racer Brown stick
you're still runnin'
I'm an EPS dipshit and you are right to a point, however Geoff designed the
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I'm not taking any credit away from ANY cam vendors on this site. If thats what you got out of it then I'm not sure I can help you with your problems.
ol days like Schneider, Isky, Engle, Cam Dynamics, Clay Smith, Camonics, etc.
My point to you sir is quit knocking on those who are fans of the new and
improved technology if you're still running dinosaur stuff.
#32
I never thought you'ld ask......Racer Brown was a cam grinder from the good
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
#33
#34
Well, here’s the deal. EPS is the best there is, plain and simple. I mean, Geoff wakes up in the morning and pisses excellence. And nobody can hang with his stuff. You know hes just a big American Cam designing machine. If you ain’t first you’re last. You know what I’m talking about?
HAHA had to do it!
HAHA had to do it!
#35
HAHA had to do it!
HAHA had to do it!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#37
QUOTE=01ssreda4;14838498]Please explain exactly what "dinosaur stuff" I'm running. I'm all ears.
[/QUOTE]
Howards and General Kinetics just called to say that Cam Motion stuff is old!!!
When you're done bashing on the EPS cheerleaders, give Pat G. a call to find
out where it's at.....I got 2 turntables and a microphone.......
All in good fun sir I truly mean no harm
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
#38
I just had this convo today I had Patrick G spec me a "custom" cam for a stock cube max effort cam only LS1....
I read the specs off to a friend who was building a 388 H/C setup who also had a "custom" cam speced
identical![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Yes these cams perform well at least his smaller ones do I haven't seen any dynos of the larger ones.
But saying each cam is speced out based on your setup is complete BS
identical
