ms3 and 36lb injectors
ok. just finished my install. ms3 cam, ls6 ported/shimmed oil pump, ls2 timing chain, 36lb/hr injectors, 1 7/8 tsp lt's. car fired up fine but ofcourse wont idle and is loading up with all that fuel. getting a p0300 multiple missfire and egt codes, which i'd say is normal. just wanted to double check on here that this is normal. planning on sending the pcm to TSP for a tune. any opinions on this?
