compression ratio for pump gas
Old Apr 27, 2011 | 10:14 AM
mark21742's Avatar
Default compression ratio for pump gas
Ok, so if my math is right on this=
4.030 bore
4.000 stroke
58 cc chamber
6 cc valve relief
Would give me 12.49:1 static compression
But with my cams intake closing at 85 degrees abdc my dynamic compression would sit at 8.22:1......
Camshaft is a comp 305 255/263 .624/.624 115lsa
This would be the perfect compression ratio for 93 octane and the most power if I am correct.
Any thoughts?
Old Apr 27, 2011 | 06:48 PM
mark21742's Avatar
Any takers?
