Oil pump problem
Old Apr 28, 2011 | 01:44 AM
blocc monster's Avatar
Default Oil pump problem
Hi guys, Just finished my build and I have a GM performance oil pump but my oil pressure is only reading 20 psi hot at idle. What is the problem I feel like I should have more oil pressure. My rod and main clearance are .002. Do you guys think I should swap out the pump and then I will be fine. Any help will be appreciated!!!
Old Apr 28, 2011 | 03:36 AM
poweredbychevy's Avatar
check the o ring on the pick up tube.
Old Apr 28, 2011 | 06:52 AM
Paul 75 L82's Avatar
Yeah, it's the o-ring. It's really a PIA the get the o-ring in correctly. I put grease on the o-ring and up in the pump to help it slid in without kincking. It's a terrible thing to think about removing the balancer to be able to get to the pump but it's really the best bet on what's wrong.
Old Apr 29, 2011 | 07:35 PM
indyboom's Avatar
I had the same problem once.. had white suff all over me, turned out I blew a seal... arrff arrrff
Old Apr 29, 2011 | 08:23 PM
JRENIGAR's Avatar
Blew a seal ehh, how bout a penguin???
Old May 2, 2011 | 10:57 PM
indyboom's Avatar
lol.... least one got it!!!
