smoke coming out of dipstick?
Old Apr 28, 2011 | 10:44 PM
dlross's Avatar
Default smoke coming out of dipstick?
i have some smoke coming out of the dipstick. i just changed the headgaskets because the driver side blew out. didnt do it before i tore it apart. Is it possible that the pcv system is clogged? i didnt think of cleaning it out. thanks for the help!
Old Apr 28, 2011 | 11:38 PM
pHEnomIC's Avatar
How much smoke are we talking here?
Old Apr 28, 2011 | 11:40 PM
dlross's Avatar
not severly but noticeable
Old Apr 28, 2011 | 11:49 PM
LilJayV10's Avatar
Do you think it could be moisture evaporating from the crankcase? Is it pushing the dipstick out or just smoking from it?
As you mentioned I would check you PCV system.
Old Apr 28, 2011 | 11:51 PM
dlross's Avatar
no not pushing the stick out just "steaming" you could say. i was going to clean the pcv system but just got a lil late so i figured i'd ask
Old Apr 29, 2011 | 12:38 AM
cowboysfan's Avatar
I hate to mention it, but are you sure the head gaskets were installed correctly?
Old Apr 29, 2011 | 06:38 AM
dlross's Avatar
yea with the correct tq specs and order.
Old Apr 29, 2011 | 08:22 AM
XtremeDime's Avatar
Check your PCV valve to make sure it is operating correctly, Id replace it to be sure. If your motor isnt venting crankcase gases to the intake manifold it will try to get out anyway it can, but the oil dipstick is not a good place for it to do it.
Old May 5, 2011 | 08:21 PM
dlross's Avatar
Yea it was the pcv system. All the hoses were cloged. Cleaned them out and replace the valve. Thanks for the help.
Old Dec 12, 2016 | 03:07 AM
z28boycali's Avatar
Old thread but I'll like to revive it since I see valuable information. I'm having the same problem some smoke coming from dipstick not a lot but just small to alert me to be caution since I love my car.
I'll be purchasing a brand new PVC valve tomorrow. Now my question is how the heck you unclog hoses? I'm ready to do that ASAP!
Old Dec 12, 2016 | 08:51 AM
zachm89's Avatar
Get a can of the aerosol Seafoam Deep Creep. Should clean it out well and be safe to use on the rubber and hard lines.
Old Dec 12, 2016 | 01:34 PM
z28boycali's Avatar
Nice I have used this product before to clean my gas tank. As for the PVC system I haven't what would be the way to spray onto the lines? What's the procedure you guys would recommend ?
Old Dec 12, 2016 | 04:47 PM
zachm89's Avatar
The deep creep comes in an aerosol can, kind of like brake or carb cleaner with a little straw attachment.
Old Dec 18, 2016 | 12:45 AM
z28boycali's Avatar
no bs. I changed pvc valve as a few of you recommended and wow! Big changes I've noticed, first it idles amazingly, second gas mileage has been great I've noticed. What a difference a $4 dollar part makes. I still have cleaned my pvc line but I will and have already purchased aerosol
Thanks all
