Help! In the middle of H/C Swap
Old Apr 30, 2011 | 06:27 PM
StormesRacing001's Avatar
Default Help! In the middle of H/C Swap
We are in the middle of swapping my heads and cam for some Stage 2.5 LS6 Heads and a TSP Tsunami cam...We ran into a problem or we think it is a problem anyway...When we put the cam in, it seems like it goes too far back. We've done LS cam installs before and have never encountered this. Please help! I can't find anything in the writeups. I appreciate your help in advance.
Old Apr 30, 2011 | 08:17 PM
94lt105's Avatar
What do you mean by it's going back to far? Explain a lil bit more! I have the tsunami cam and didn't have one single problem with the install! Let us knwo more of what u mean so we can help man!
Vinny
Old Apr 30, 2011 | 10:23 PM
jsteele90's Avatar
you sure youve done a cam swap before? just slide it in and bolt it up.
Old Apr 30, 2011 | 10:29 PM
ski23's Avatar
When you bolt the retainer plate on it will pull cam back in place for the line up pin to sit in the cam gear.
Old Apr 30, 2011 | 10:32 PM
When we slide the cam in and put the cam retainer plate on the cam can move back and forth about a 1/4 inch between the cam retainer plate and the back of the block. Yes, we have done two LS1 H/C swaps prior to this one. I just dont remember seeing this before.
Old Apr 30, 2011 | 10:34 PM
jsteele90's Avatar
once its bolted to the retainer plate like ski23 said. just move on. i wouldnt worry about it.
Old May 1, 2011 | 09:01 AM
408Maro's Avatar
That's what happens bro. Put it on flush and bolt the plate on
Old May 1, 2011 | 09:19 AM
Pocket's Avatar
Retainer prevents it from moving forward, cam gear prevents it from moving backwards
You're fine, abnormal is when it slides off a main or wont go in all the way
Old May 1, 2011 | 09:21 AM
Thanks for the replies guys!
Old May 1, 2011 | 11:32 AM
WS6tx's Avatar
Bolt it up and make some power man. you may not have noticed it in the past.
Old May 5, 2011 | 06:58 PM
20sickss00's Avatar
I just did this exact setup a couple weeks ago to my car, runs strong! you'll be happy!
Old May 5, 2011 | 07:12 PM
Got it tuned today! I freaking love it
