Fuel sending unit?
Old May 5, 2011 | 06:38 PM
Sunset_Orange_WS6's Avatar
Default Fuel sending unit?
My car only reads my gas when Im driving. When I come to a complete stop after about 30 seconds it drops back down to empty. Is replacing the fuel sending unit hard?
Old May 5, 2011 | 07:32 PM
chrisfrost's Avatar
Sounds to me like the gauge . If it's an analog gauge , there is a resistor on the back of the gauge that almost always is the culprit when gauge is innacurate . If it's digital , it could be in the gauge cluster computer or possibly the sender . The fuel sending unit wiring can also can be a problem . There is a positive wire to the sender and a ground wire that goes from the sender to body ground and sometimes the ground develops high resistance . Good luck
Old May 5, 2011 | 08:23 PM
sjsingle1's Avatar
the sender design is faulty from GM.......the arms that sweep the face of the sender in the tank do not make full contact because of slop in the bushing that holds the thing together........plus the sender gets all kinds of crap on it that only comes off if you take it out and clean it
