new cam thats nitrous friendly?
Thanks for the information
Personally; knowing that you have good compression which nitrous loves, a cam that is a good jump up from stock and will work pretty well with nitrous, and that you will have to pull your heads and flycut to run a larger cam most likely. I would say its not worth it to go through all that and gain maybe 20 horsepower for all that work. I would just run a little bigger jet for the n2o.
Thats is good enough for Nitrous. Unless you dont mind spending the hours and money working on your car, a 232 cam isnt going to give you much difference at all. Especially if your staying with a 114LSA Which is a good decision. Estimated RWHP gains from going from a 225 cam to a 232 Might be about 5-8RWHP. Something to think about.
I do have that cam. When/if I change cams I will go to a 113 LSA. I'm still undecided on whether or not I want to change cams as of yet. Trying to figure out where my money is better spent in the long run. Indecisiveness and never being happy with my power always kicks my butt.
I know you have that cam. I just copied and pasted it to my post. But what I am saying is that unless your going with a "MS3 or MS4" "STYLE" cam(as far as duration) I wouldnt change your cam. I would spend the money on gears or a great TNT Kit.
Already have a Moser 12 bolt with 4.10s
Nitrous will definitely happen either way
