Bearing Vendor
Kwikcad500-Mallory? Whats that? And it will vibrate that bad? I was going to have the rotating assembly balanced, but i didnt know it would affect harmonics that bad.
I was recently planning to use a 5.3 crank which has the same casting numbers as the 6.0 crank in my build but the front and rear rod journals were
heavily drilled and would have taken quite a bit of mallory to balance with my heavier dome pistons. Also when mallory is needed on the rear most counterweight the reluctor ring must come off. The LS1 5.7 crank is lighter than the LQx 6.0 peice so your machine shop will just have to add mallory where it's needed. It can get expensive(mallory itself) depending on how much is needed so ya may want to talk with your machine shop before getting too deeply involved. Hope this helps.
Yes, rod bearings are sold as individuals, so you can get singles of any size rod bearing, no problem!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
