nitrous on an eps 230/234?
Old May 9, 2011 | 01:25 PM
brian_rs/ss's Avatar
Default nitrous on an eps 230/234?
ok so had pat spec me out a cam, came up with an EPS/LXL lobed 230/234 .600/.610 112 lsa. i'm considering spraying a little nitrous through a plate. i'm thinking it will be fine with the split and lsa, but just wanted a second opinion as i've never used nitrous. btw the build consists of pp'd & milled 799's, ls6 valves, 1518 springs, Ti retainers, stock rockers with trunion upgrade, through an ls6 intake and pacesetters. pretty sure this valvetrain should handle the n2o but let me know what you think.
Old May 9, 2011 | 01:38 PM
kinglt-1's Avatar
That cam will work fine...you dont need to worry about a nitrous specific grind till you start spraying over a 200 shot.
Old May 9, 2011 | 03:01 PM
c0ncEpT's Avatar
Many people have sprayed reverse split cams with decent shots. While it may not be ideal its works just fine.
You wont have a problem.
Old May 9, 2011 | 03:03 PM
*02WS6TURK*'s Avatar
Should be just fine. Awesome cam choice. Keep me posted on your results.
Old May 9, 2011 | 05:32 PM
180ls1's Avatar
like the others have said, it will be golden
Old May 9, 2011 | 07:32 PM
s346k's Avatar
hell man the stock cam loves n2o. i wouldn't worry about a nitrous specific grind until you get into the 300+ range.
i've seen a plethora of cams (stock and aftermarket) do great on 200-250 shots.
Old May 10, 2011 | 02:38 AM
awesome
can't wait to carry out my evil plot
Old May 10, 2011 | 03:22 AM
Cold Zero's Avatar
If you will spray below 150 shot mark .. the cam has nothing to do with nitrous ..sure it will be fine .. do it and enjoy the 1st time feeling
The nitrous cam is customized to eat the 250 - 300 shot
