Injector Horror Story (Internal engine related)
.001-.003" or so difference in OAL will not show in a compression test..
Im sorry but Im a manufacturing engineer so Ive got fluid & machining expertise on my side. .001" difference in OAL could only be a .0007" deflection in the "xy" direction of the motor.
.0007" deflection is enough for a 6 inch+ length that the bearing will eventually side wear and then trash the crank, causing catastrophic engine failure.
I was afraid this had happened to me with my GTP.
I too, bought rebuilt injectors and a tuned pcm from ZZP back in the day.
I had a 3.2?" pulley, injectors, headers, ported tb, and methanol injection
few weeks after installing injectors and PCM motor blew up, put a rod through the block, etc. I never even tore it down. I was too upset & young to realize slash care about anything other than the money I spent on the car plus the mods practically broke me, then I didnt even have a car. Sold it to someone who had wrecked their car, and they came and got it.
ZZP assured me that with the exact mods I had the pcm they sold me would be the right one. They said I didnt even need to get it dynoed if I didnt care about anything besides spanking 'camaros'. Anyways I would definitely pull the motor and get everything measured up. Measuring is cheaper than rebuilding a blown up motor.
Well as a mechanical engineer... I think that the starter tab breaking acted as a mechanical 'fuse' limited the amount of force put into the rod. Its all speculation, but the compression test in my mind would be an indicaor... I feel comfortable running my car for the season.
You must be one of those engineers that think a slip fit can be achieved with +/- .005 tolerances. And you probably buy critical engine parts from china.
Good day sir.
At least I won't chime in on your rebuild thread and say "I told you so"
Good day sir.
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
https://ls1tech.com/forums/generatio...ked-block.html
a comp test wont tell you a thing unless you have a major bend or twist
![](http://i312.photobucket.com/albums/ll343/mattster03/IMG_1686.jpg)
![](http://i312.photobucket.com/albums/ll343/mattster03/IMG_1687.jpg)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
As a wise man on another forum I frequent reminded me "If it looks like a turd, smells like a turd, and feels like a turd... did you really need a taste test"?
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
you guys can keep arm chair second guessing me, trust me, I'm not happy that their product didn't live up to their guarentee, and I probably won't buy another used part in my life. It is what it is.
#33
https://ls1tech.com/forums/generatio...cting-rod.html
If you havent blown it up yet and have any possibility of removing head from ***..
#34
1. His starter did not immediately break and disengage.
2. His engine started.
3. His engine was making noises afterward.
#36
I agree with you fully on this... I am closely monitoring my engine for any signs/sounds of rod knock. I have well over 300 hard-driven miles on the car since the 'incident'.
#37
Funny, I left an e-mail with the vendors who sold me these injectors and haven't heard back...
"I recently purchased a set of clean and flowmatched ZZPerformance
injectors from ebaymotors auction #XXXXXXXXXXX , tracking
#XXXXXXXXXXXXXX . To begin, I was severly disappointed in the
condition of the injectors, they were poorly spray painted (not dyed
as, with overspray all over the pintle areas of the injector and badly
chipping allowing white paint flakes to enter the injector filters and
other critical areas. After having the injectors properly installed
on my car by a professional we came to find that one of the injectors
was stuck wide open when the injector filled one of the combustion
chambers with fuel causing the engine to hydrolock during startup
breaking both the starter and potentially bending a connecting rod.
Your product did not live up to the guarantee stated on the auction
page to flow within 2.5% and did not perform as new... and if it were
properly re-manufactured and checked as claimed would have not caused
this extensive damage. The injector was confirmed to be stuck wide
open once removed. I am a very unsatisfied customer! Please let me
know how to return the injectors for a full refund + shipping. In
addition, please explain how you plan to rectify the situation with me
to keep your good reputation as a high quality vendor on eBaymotors,
clubGP as well as other automotive performance forums and. Thank you,"
#38
Face it you got cornholed, PLUS you let them. Next time think a little more. I've been in your situation and got screwed too, its hard to believe there are people out there that woooood do sheeet like this but today its common.
