Wiped cam lobe and damaged lifter
Old May 13, 2011 | 12:30 PM
LSCha0s's Avatar
Sorry to hear that.
The same thing happened to me a couple of months ago. My cam was a regrind. I decided to put an LSX in my car instead of fixing it. Its a 91 Vette.
Old May 13, 2011 | 12:50 PM
mike171562's Avatar
Its possible to get the lifters out without pulling the heads?
Old May 13, 2011 | 02:06 PM
Schitzo's Avatar
I have been wanting to get a F13 cam and while doing some searches I found similar issues with this cam.isn't it likely to be the case here.Any one know if the new F13s have the same issue?
https://ls1tech.com/forums/generatio...ror-story.html
Old May 13, 2011 | 02:09 PM
c0ncEpT's Avatar
Sure. Pull the cam out and let them fall into the oil pan.
Good luck getting them back in tho
All kidding aside the answer is no. On an LS motor you have to pull the heads to gain access to the lifters.
Old May 14, 2011 | 05:14 PM
darknessxyz's Avatar
When a small cam like mine (224/230 .588/.588), did you guys recommend shimming a .650 dual spring or just go with a set of .600 single?
There's two different shop doing my head and motor. I need to let the shop know what I wanna do.
