Anti seize-aluminum heads
First time to work with aluminum heads, and was wondering about using anti-seize lube for all the bolt ons.
I know to use it for the spark plugs but wondering about all the steel bolts for the brackets and also the rocker arm bolts.
Thanks
Thanks
https://ls1tech.com/forums/general-m...ue-values.html
Relevant to your question (I hope).
The following users liked this post:
Bigbirdtrucker (02-09-2020)
I can't give you the answer to your question, but this is a pretty interesting thread:
