Lost and confused
Old May 16, 2011 | 11:40 AM
souljaboy9768's Avatar
Default Lost and confused
I have a 2002 z28 ls1/m6
Where to start I ran the check engine light and it came up random missfire. I took it to a local shop And they said it was cylinder 7. I changed plug, coil and wire and the miss has not went away. At normal idle their is a small miss but when I take off there doesn't seem to be loss of power. I notice when I'm on the highway at 70mph in 6th gear at 1500rpm check engine light turns on. I can down shift till 5th and stay at 2000 rpm and the light immediately turns off. I notice a exhaust leak this morning coming from the driver side... I feel like I can't get rid of this problem soon I'll get rid of the car!! HELP please.
Old May 16, 2011 | 04:40 PM
5.3LJimmy's Avatar
It could just be the exhaust leak messing with the oxygen sensor causing the rough idle. If you don't notice a loss in power then it is likely not an actual miss. I wouldn't waste any more time/money changing parts until you fix the exhaust leak.
Old May 16, 2011 | 08:01 PM
Thanks a lot, I'll try tomorrow and let you know
Old May 16, 2011 | 08:42 PM
Lt1Porsche's Avatar
Whats the setup? Any cam? Rockers? Any recent work done?
