ok need help
Old May 17, 2011 | 11:30 PM
silverz28ls1's Avatar
Default ok need help
ok i spun a rod bearing so im replacing everything except the crank i was looking at texas speed and saw Callies Compstar rods,Wiseco pistons...im on a budget so which ones should i go with to get more power i have baught ls6 heads and ms4 cam i need help getting the rods and piston situated and head gaskets want to keep the compression at a safe level seeing how this is my dd
Old May 19, 2011 | 01:11 AM
any help.......
Old May 19, 2011 | 01:26 AM
01ssreda4's Avatar
You need to call the vendor you are going to buy the parts from and let them set you up with what will work together correctly.
Old May 19, 2011 | 01:31 AM
shorty(98TA)'s Avatar
^agreed the boys at texas speed know their **** and are super helpful. Id deff give them and call they ill be more than happy to talk over your setup with you
