.050 mill safe for heads with ....
Old Feb 24, 2004 | 10:41 AM
Reckless's Avatar
Super Moderator
Default .050 mill safe for heads with ....
.581/.591 lift cam? 224/230 112
Old Feb 24, 2004 | 10:54 AM
DEVIATE's Avatar
Only if you plan on flycutting the pistons. That is to much for even a 224 581 112 comp cam
Old Feb 24, 2004 | 10:56 AM
Reckless's Avatar
Super Moderator
Thai s what I was thinking. Anyone else?
Old Feb 24, 2004 | 11:06 AM
Xerxes's Avatar
Yeah, I say flycut the pistons. How about shorter pushrods?
Old Feb 25, 2004 | 05:45 AM
Spinmonster's Avatar
With -2cc reliefs I had .212 with that cam on the intake side and .035 milled. Taking the .165 away from my flycutting-leaves.047 and your additional mill of .015 is .032 of clearance....I wouldn't run that cam without 3 times that. Flycutting .065 is the minimum and you better check the clearance again. The powerband of that cam is to 6700-6800. At those speeds thing strettttch. There is also valve float which is an issue for XER lobes with insufficient springs.
Old Feb 25, 2004 | 09:14 AM
Reckless's Avatar
Super Moderator
I'm just having the heads milled .020 and not touching the pistons.
Old Feb 25, 2004 | 09:21 AM
ONEBADWS6's Avatar
I had .40 off my 5.3 heads and a 224/ .581 cam. I had no PV problems at all.
