CORRECT PUSH ROD LENGTH
THANKS, JAMES
I measured the stock cam from my 99 LS1 perpendicular to max lift and got 1.552" so radius is .776"
My new cam is 1.496" so radius is .748"
So new cam needs a .028" longer pushrod to keep the same rocker position/preload. However, since my heads are milled .030", that means the pushrod needs to be that much shorter so final size is .002 inch shorter then stock, or 7.398". Since you can't get that, and doesn't matter that close, I need stock length.
This base circle difference gets worse as you go to higher lift cams. The one in my example is a .560" lift.
HTH,
George
