Cam help please!!!!
Old May 20, 2011 | 10:16 PM
TexasTarnation's Avatar
Default Cam help please!!!!
Alright guys I need some help BAD!!! I got a 2000 Z28 A4.Ive got LS6 intake,SLP lid and tune done by Texas speed.My question is I want a very mild cam that will boost performance.I know it would be better to get heads to match them but I dont have that much.I also intend on headers and cold air intake.And of course smaller crank pulley.Any HELP would be appreciated and also some other things that will help with perfomance without costing me alot like a procharger or turbo.I want naturally aspirated.Thanks guys!!
Old May 21, 2011 | 12:21 AM
Duffster's Avatar
...mild... Go with something in the range of 0.550-0.580ish on the cam with a 112-115lsa. Durations will probably be in the neighborhood of 224-230/226-236 and still be 'mild'. Consider springs too.
GL
Old May 21, 2011 | 12:28 AM
HWI's Avatar
HWI
Stall.
Old May 21, 2011 | 01:05 AM
99Bluz28's Avatar
As stated above, go with a stall first.
Old May 21, 2011 | 01:27 AM
nwalton29's Avatar
Please get a stall. then get some 1 3/4 headers. should be dirt cheap as now everyone is trying to go 1 7/8 or bigger.
Old May 21, 2011 | 02:07 AM
2slow2flurry-ous's Avatar
Stall>cam
Old May 21, 2011 | 07:26 AM
crainholio's Avatar
That was a statement, not a question.
Old May 21, 2011 | 08:07 AM
LS1121's Avatar
Mild would be a Z06 cam, I think that is where I,m going.
Old May 21, 2011 | 10:47 AM
buzb026's Avatar
use the search button!!
Old May 21, 2011 | 12:09 PM
01ssreda4's Avatar
OP are you planning on a stall?
Old May 21, 2011 | 12:18 PM
99Bluz28's Avatar
Maybe ultra mild/small.
I'd look into a 212/218, over a Z06 cam any day.
Old May 21, 2011 | 01:40 PM
garygnu's Avatar
stall-further mods-tr224-retune.
Old May 21, 2011 | 01:50 PM
LS1121's Avatar
From what i read with the 04 Z06 everything you need can still be stock. But this is justmmy opinion.
Old May 21, 2011 | 10:06 PM
somethingelse's Avatar
+1 on the 212/218 115
That is what I started with. It has a great increase in torque and power, does not have a lot of lope, doesn't kill your mileage and has a XFI lobe that is less aggressive than an XE-R lobe, so it is easier on your valvetrain. If you don't want to change springs every 30k, that is a good one to consider
Old May 22, 2011 | 01:03 AM
01ssreda4's Avatar
We cannot help you as you have not told us what we need to know.
