bought my camaro with mods.... need cam specs
Old May 22, 2011 | 02:00 PM
ss3627's Avatar
Default bought my camaro with mods.... need cam specs
i bought my ss with several mods.... i have ran into some trouble with the push rods....
was told my cam is a comp cam 232/236 ... anyone know the specs on this cam ...
would the specs be alot like the 232/234 ????
now im wanting to fix my issue but keeping getting diffrent answers and info
I have decided on:
comp cam chromemoly 7.400 push rods
a new set of rockers ( just incase )
and a set of patriot extreme dual valve springs ( have mixed feelings on these...ws6store highly suggest these but i have a guy around here saying they are trash....
HELP ON THE SPECS AND ANY OTHER SUGGESTIONS ARE WELCOME ....
THANKS GUYS!!!
Old May 22, 2011 | 03:28 PM
Duffster's Avatar
There needs to be more info. IF you knew the grind # that would help. the #s you list are the duration (how long the intake/exhaust are open). Those numbers most likely correspond with a decent lift cam but guessing the #'s won't help. If the seller could tell you a bit more, OR if you yank the cam out...
Not as much help as you thought you might get, but anything else is guessing...
Old May 22, 2011 | 05:05 PM
ss3627's Avatar
yeah i agree more info would have been better but no idea ... defiantly not trying to pull the cam
