Does this look normal?
Old May 22, 2011 | 09:25 PM
hdkarmy's Avatar
Default Does this look normal?
Opened up an LQ9 to freshen it up and this is what I found. Its out of a 2002 escalade with 120,000 miles. Everything looked great, no metal in the pan at all. Was running good, I was just going to hone and put new rings, rod bolts and cam bearings. Cam bearings showed a little brass and the cylinders showed no cross hatching but other than that it looks great. Its just the front and rear by the lifter bores. The center two look normal. I know it has never been open before. Just wondering if I should be concerned or if any one has seen this from GM before?
Attached Thumbnails Does this look normal?-p5220063.jpg   Does this look normal?-p5220064.jpg   Does this look normal?-p5220065.jpg   Does this look normal?-p5220066.jpg
Old May 23, 2011 | 04:33 AM
mark21742's Avatar
Nope, that's the way they look, your good to go
Old May 23, 2011 | 08:59 AM
Jon@Texas-Speed's Avatar
Yeah that's normal for these motors. Nothing to be worried about.
Jon
Old May 23, 2011 | 05:47 PM
hdkarmy's Avatar
thanks guys
Old May 23, 2011 | 08:22 PM
KILLER-LS1's Avatar
yeah, that is the opening into the valley area of the motor. there should be 2 openings like that.
