lq4 swap on a budget
Old May 25, 2011 | 04:10 PM
camross998's Avatar
Default lq4 swap on a budget
im swapin a lq4 into my 99 t/a with stock stuff heads stock cam is the lq4 cam with ls1 intake no LT would it also be safe to drive without a tune
Old May 25, 2011 | 06:38 PM
mark21742's Avatar
Is atleast get s wideband gauge hooked up, but it "should" be ok to drive for awhile if you use your stock ( from your car) injectors
Old May 25, 2011 | 07:55 PM
KILLER-LS1's Avatar
yes as long as the injectors stay the same, it should be pretty close. id still get it retuned though
Old May 25, 2011 | 08:43 PM
camross998's Avatar
what kinda whp i would be look at before the tune and afterwards
Old May 26, 2011 | 05:20 AM
mark21742's Avatar
Stock for stock you gain more torque and it will come into the power earlier at lower rpms. I've seen people gain 5 hp from a tune and I've seen others gain 35+ hp, so its hard to say
Old May 26, 2011 | 09:15 AM
dre2013's Avatar
with a stock lq4 you'll probably dyno around 320ish. maybe a little lower due to low comp ration
Old May 26, 2011 | 09:31 AM
mark21742's Avatar
Thats right, I forgot about the didhef pistons
