budget 408 head....
Old May 27, 2011 | 12:34 AM
Raven02TA's Avatar
Default budget 408 head....
Started acquiring all the parts needed for my 408 build. got the bottom end parts and hae yet to get it assembled. ran into a work/budget snaffu that i really cant get into explaining. would take too long. basically. taking a pay cut (temporarily) and also moving is taking away from the budget for my motor build.
anyway. i would like to just get the car running to at least enjoy driving it until i can afford a better set of heads and a better cam. I still have my TREX cam from my built ls1 so ill re-use it until i decide to get a cam spec'd out.
i plan to use a fast 102 intake/tb. my biggest issue is acquiring a set of decent heads that i can slap on for the time being. just dont know what i should be looking for.
any suggestions? preferably looking for something i would be able to find in the ls1tech classifieds section when i can afford it.
running wiseco flat top piston with -3 cc valve reliefs.
Old May 27, 2011 | 12:38 AM
jrob56's Avatar
some stock ls3/l92 heads would seem to be the no brainer budget head. they seem to come up pretty often on camaro5
Old May 27, 2011 | 12:40 AM
Raven02TA's Avatar
thanks, thats what i was figuring would be a decent head. just wasnt sure. i havent been keeping up on any of the new stuff lately. been out of the R&D game for a while. trying to get back in.
Old May 27, 2011 | 04:18 AM
itsslow98's Avatar
Yep L92s will be a great head for you.
Old May 27, 2011 | 08:33 AM
Raven02TA's Avatar
any opinions on putting L76 heads on? was offered a pair of 5k mile L76 heads for $400
whats the difference between the 2?
Old May 27, 2011 | 08:49 AM
Raven02TA's Avatar
talked to the guy some more. they are casting 0821. which i guess is the ls3/l96 head. for 400 bucks....
im all over it if thats the case
Old May 27, 2011 | 11:36 AM
SOMbitch's Avatar
The only difference between the two is the LS3 heads have lighter valves...
Old May 27, 2011 | 01:29 PM
jrob56's Avatar
yep
and for 400 id def take them, if you look in the thread below you can make sure you have the ls3 lighter valves.
https://ls1tech.com/forums/generatio...omparison.html
