Pushrods for 228r cam?
Old May 31, 2011 | 11:11 AM
Jon@Texas-Speed's Avatar
That's fine if he recommended that. We sell and install a ton of them and there seems to be a little variance in the cam cores recently. We installed the exact same cam in a car last week with stock heads that took a 7.350" pushrod and setup with .065" preload. That's why we stress so much to measure each setup!
Jon
Old May 31, 2011 | 11:51 AM
Paul 75 L82's Avatar
I used the 7.4" rods in mine with great results. No noise and great power.
Old May 31, 2011 | 12:57 PM
Patrick G's Avatar
LS1 Tech Administrator
Guys, it's pretty simple math. The stock LS1 cam has a base circle radius of .7755" and runs a 7.38" pushrod. This gives a lifter preload that offers low noise and good long term performance. When running a stock LS1/LS7 lifter, I prefer to run a preload that's the same as factory.
A 228R cam has a base circle radius of .7265". That means the 228R cam has a .049" shorter base circle radius than the stock cam. If you are trying to maintain stock lifter preload with the 228R cam, you will need to run a .049" longer pushrod than stock .7755"-.7265"). Adding .049" to the stock 7.38" pushrod length gives you a 7.429" pushrod. The 7.425" pushrod comes closest to maintaining factory preload with the 228R cam. If you run a 7.400" pushrod, it will work, but you will be running .029" shallower preload than stock. If your LS1 is at the shallower end of lifter preload tolerance, you may get some lifter noise with a 7.400" pushrod. With the 7.425" pushrod, you will have a better chance of having a quiet setup because the lifter is more in the middle of it's plunger travel (like the stock LS1).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old May 31, 2011 | 01:29 PM
I understand the math. But what I'm trying to to tell you guys is we have seen some variance in base circles on the cams we have installed lately. Joseph knows a thing or two about these engines. If he comes to me telling me there is something different in the cams and the last couple he installed were different, I am inclined to believe him and I try to pass that info. along here. All I'm saying is to measure the length. At the end of the day, it's your car and you can do whatever you please. Just trying to give you a heads on something to look out for! Good luck with it!
Jon
Old May 31, 2011 | 04:48 PM
z99ls1's Avatar
Restricted User
Jon
So the cams are that much out of spec?
Old Jun 1, 2011 | 01:05 AM
01ssreda4's Avatar
Measure to be sure....and read and understand Pat Gs post because its spot on.
Old Jun 1, 2011 | 01:18 AM
bonethugluv's Avatar
Pat sounds like he knows his stuff very well. I used a 7.4 in my 228r for a couple yrs and car was always quiet as stock too. but like they say, measure to be sure.
Old Jun 1, 2011 | 01:49 AM
01ssreda4's Avatar
I know Pat G is correct because i measured my stock cam and my TR224 that went in years ago and did the math to compare. I ran 7.425 pushrods with that and it was silent. Aftermarket cams are cut on a smaller base circle.
Old Jun 1, 2011 | 11:28 AM
DUSTYWS6's Avatar
I followed Pat G's logic when I put my 228R in. I got a digital caliper and measured my stock cam base circle and 228R base circle and determined that I needed 7.425" pushrods. I was pretty impressed with GM's quality control on the base circles, each one was identical.
Old Jun 1, 2011 | 06:18 PM
z99ls1's Avatar
Restricted User
So pretty much if I measure my 228r and get .7265", than I know I need the 7.425 pr's
Old Jul 21, 2011 | 11:28 PM
z99ls1's Avatar
Restricted User
Sorry to bring up an old thread, but I would like to pick my pushrods based on how pat g said to do it above and measure my stock cam and aftermarket cam lobes to see what I need. So how do you measure the base cicle of a cam lobe?
Old Jul 22, 2011 | 01:10 AM
  #32
ZeeOSix's Avatar
Measure across the top peak of a lobe to the base circle, and then subtract the lift spec of that cam lobe (depends if you measured an intake or exhaust lobe) to give you the base circle diameter. Then divide that diameter by 2 to get the base circle radius.
Do this measurement on a couple of lobes and see if you get the same answer. You should, as the base circle radius should be the same for every lobe. But be sure to subtract the lift spec for the intake lobe if you're measuring an intake lobe because intake and exhaust lobes will have different lifts.
Old Jul 22, 2011 | 01:32 AM
  #33
z99ls1's Avatar
Restricted User
Originally Posted by ZeeOSix
Measure across the top peak of a lobe to the base circle, and then subtract the lift spec of the cam to give you the base circle diameter. Then divide that diameter by 2 to get the base circle radius.
Ok so if you have to subtract the lift spec from the cam and you have an intake lift of .598 and an exhaust lift of .650 than technicly wouldn't you need a different pushrod for the intake and exhaust sides?
Old Jul 22, 2011 | 01:40 AM
  #34
ZeeOSix's Avatar
No ... because when you measure lobe to base on an exhaust lobe it will be a larger number because the lift is larger on the exhaust lobe.
So when you subtract 0.650 from an exhaust lobe measurement it should be the same as when you subtract 0.598 from what you measure when you go across an intake lobe. The cam's base circle is the same on all lobes, and all 16 pushrods will therefore be exactly the same length.
Old Jul 22, 2011 | 01:48 AM
  #35
z99ls1's Avatar
Restricted User
No ... because when you measure lobe to base on an exhaust lobe it will be a larger number because the lift if larger on the exhaust lobe.
So when you subtract 0.650 from that measurement it should be the same as subtracting 0.598 from what you measure when you go across an intake lobe. The base circle is the same on all lobes, and all 16 pushrods will be exactly the same length.
Ahh alright. Well if we could get some accurate base circle numbers from our cam supliers, getting pushrods would be a cake walk. I am just about thinking of calling up tsp or thunder racing (wichever will do this for me) and asking them to measure the base circles of some of these cams and see what there getting.
Old Jul 22, 2011 | 01:52 AM
  #36
ZeeOSix's Avatar
True on that.
Better yet ... if you know who actually designs & makes the cam, then give them a call, as they should know the exact base circle and the IN/EX lift dimensions of all their cams.
Old Jul 22, 2011 | 01:59 AM
  #37
z99ls1's Avatar
Restricted User
True on that.
I think me and you are on to something here lol
Old Jul 22, 2011 | 02:02 AM
  #38
01ssreda4's Avatar
Or you could measure where there is no lobe, that's what I did.
Old Jul 22, 2011 | 02:08 AM
  #39
z99ls1's Avatar
Restricted User
Like from side to side on the cam lobe? Im not sure if that would be accurate or not...
  #40
ZeeOSix's Avatar
As you can see in this photo, the base circle at the lobes is not the same as the base circle between the lobes.
