Bosch 160lb injector tuning
Old May 30, 2011 | 11:56 AM
ls1player's Avatar
Default Bosch 160lb injector tuning
Everyone,
I need some advice. I am switching my cars to run E85. I had 95lb injectors and i switched to Bosch 160s. The only thing I switched was the flowrate vs kpa table. The injectors work fine except on idle. My car with pump gas will idle 11.5 to 1. I wasn't too concerned because I was switching to E85. Running e85 my car idles at 8.5 to 1 and I am trying to get the car to idle at 9.6 to 1. My values in my VE table (speed density tuned car) are almost zerod out and the car still idles rich.
My question: Does anyone have info on these injectors? I am looking for min pulse width info, and anything else out there. There has to be a way to slow these injectors down at idle.
I know ID makes high IMP injectors but was looking to try to make these work.
thanks,
ADam
Old May 30, 2011 | 01:01 PM
180ls1's Avatar
try the forced induction section its a little further down the the main page, post this there and see if they can help you i know many guys have the same issue.
