Another internet myth bites the dust... LS7 vs. LS1 lifters
#61
Also, make sure the ball bearing is the same size as the stock pushrod tip. That bearing appears much too large. The ball end of the stock pushrod I'm using measures out at .3115". I've measured this 10 times and keep getting the same thing. FWIW, I am using a piece of stock GM pushrod .460" long with both lifters. I am getting overall lengths of 2.7650" and 2.7655"
Shane
#62
correct, anything with a d-bar or trays.
#63
I've never worried about any difference between the two because I always measure for pushrod lengths in my engines. Also, never knew that there was a debate regarding that there may have been a difference. Regardless, most people who post information do so in an effort to help. So, if it has been posted that there was or was not a difference, am sure that the poster had good intentions.
"Internet myth" is a term that I don't like, personally. If someone posts something with good intentions & the information is incorrect, eventually, someone else will correct it & the poster will learn from it. There's really not more to it.
maybe a better term would be internet mis-information.
Shane
#65
That definitely must be the case. I only even went through this whole exercise because I have installed so many of the same cams with LS7 or LS1 lifters and time after time the preload is the same. I got so tired of hearing that the lifters were different I pulled a few and started checking. I have LS1 lifters from multiple engines and of course nearly an unlimited supply of new LS7 lifters to test.
We do check lifter preload on every install here. When we sell a cam package, we give the customer the pushrod that best fits their stated mods and most of the time we are right on. I can hardly remember the last time I used a pushrod shorter than 7.375". In almost every instance on a stock motor with a cam over .600" lift, the 7.425" pushrod is the proper choice.
Thanks for taking the time to setup your measurments perhaps I'll send you a few lifters to check out for yourself. Let me know if you are interested.
Thanks,
Shane
Thanks,
Shane
#66
We simply must have different lifters somehow. I dont think there would be a .045" tolerance stackup on a lifter.
#68
Old School Heavy
I will throw another interest twist to the discussion. I just replaced the lifters in my LQ9. The lifters looked identical meaning they both looked like the LS7 style fully shrouded lifters. When I bolted it all back together, I measured with the Comp Cams 7702-1 checker and found that I now need a shorter pushrod. In fact your measured difference of .0425" looks about right for my situation too.
#69
i wonder if there is an unspoken difference in production runs....and if there's even anyway to find out. hmmmmmm.
not that it even matters to me, i am using morel link bar lifters, but this is still a question that needs a definative answer.
#70
If a picture is worth 1,000 words, how much is a video worth?
LS2 lifters in this video were removed from my cammed LS2 (25,000 miles cammed), and replaced with LS7 lifters when I installed my LS3 heads. They lasted about 45,000 miles before failing, and taking out the cam with it.
I replaced them with Lunati / Morel Street Hydraulic Link Bar lifters, and since I've seen everyone fussing about this, and don't trust anyone, I measured. Found these differences:
LS2 = shortest
LS7 = LS2 + 0.05"
Morel = LS2 + 0.06"
www.youtube.com/watch?v=GSnKcxx8GWE
LS2 = shortest
LS7 = LS2 + 0.05"
Morel = LS2 + 0.06"
#74
My best friend has been is GM master tech, and has been working at a Pontiac (now Chevy) dealer for 30 years...I owe him a phone call.
I have the original FSMs for my GTO. I haven't looked, but I'll bet you a 12-pack, it doesn't explain anywhere in the book how to check preload.
#76
