head gasket bore size question
Old Jun 5, 2011 | 11:17 PM
mike13's Avatar
Default head gasket bore size question
I have a bore of 4.03 can I use a gasket with a bore of 4.08?
Old Jun 5, 2011 | 11:42 PM
wesam's Avatar
yes you can i used 4.10: with my 4.03 before i have 4.06 now
Old Jun 6, 2011 | 02:06 AM
PREDATOR-Z's Avatar
Yes you can
Old Jun 6, 2011 | 04:35 AM
vettenuts's Avatar
Before you buy, measure the chamber width on the head as well. Sometimes the chamber width will dictate the gasket bore size.
Old Jun 6, 2011 | 08:00 AM
mike13's Avatar
OK, I'll check
Old Jun 6, 2011 | 09:08 AM
Jon@Texas-Speed's Avatar
That's correct. You need to go with a gasket that is bigger than the bore of the heads and and block.
Jon
