aftermarket non adjustable rockers with Comp R's....
#41
Originally Posted by JF WS6
That's pretty much what I was asking earlier, and from what I gather the only reason why you'd want to shim is just because you can do it in smaller increments to get it just right. Changing the pushrod length *may* be too drastic as Spectacle Solutions said "most rods only come in .050" increments."
If you could somehow get the exact length of pushrod you needed to get the right preload that would be ok I think. Shimming is cheaper than buying a whole new set of pushrods anyway.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Here is another question, are comp R's really neccessary with most springs? I can see 977's, or real high RPM, but I see a lot of big cam cars spinning 7K out there, what do you guys think..
Dan
#42
Senior Member
Originally Posted by Brian@AP-Engineering
Country boy, a true comp R can be identified by the PRESSED in gold cup and the black oxide coating. The regular comp and factory lifters are held in by a c clip . Pictures can be found here : http://compcams.com/Technical/Catalo...ML/282-283.asp
I can take pics of them here at the shop.
Can you illaberate (sp?!) some more on this?! What black oxide coating. Is the retaining clip black or the lifter body? I was at the shop today and was checking out my lifters and the body is the standard grey. I have some pics....
#43
PSJ Wannabe & Attention Whore
In the second pic, is that a c-clip? If so i do not think those are comp r's. They look like regular comps 850-16's to me.
The black oxide outer coating is usually on the oil band area.
