01 trans-am engine removal
Old Jun 9, 2011 | 10:04 AM
stroked 4.8L's Avatar
Default 01 trans-am engine removal
hello, is it possible to remove an ls1 from the topside or is the only to remove from the bottom?
Old Jun 9, 2011 | 12:22 PM
hiltsy855's Avatar
Top or bottom - your choice. Do a search in the General Maintenance & Repair section, lots of info there.
Old Jun 9, 2011 | 01:21 PM
09camarossls2's Avatar
+2 Top or Bottom
I Did mine Through The Top..
Old Jun 9, 2011 | 02:38 PM
kmspruill242's Avatar
Yeah pulled mine up through the top. Took the struts off the hood so I could push it up a little farther out of the way. removed the intake and used a TPIS valley cover lift plate. I also removed all the front accessories.
Old Jun 9, 2011 | 11:27 PM
11seccamaro's Avatar
DId my camaro through the top..... i would recommend not having the intake on it, and if u have a/c then take all the pulleys off makes it a lot easier, especually going back in trying to get everything to line up
Old Jun 10, 2011 | 04:08 PM
1994z's Avatar
i have drop one from the bottom [camaro] and pulled two from the top [transam]. will not drop one from the bottom again. to me its quicker and less of a mess.
Old Jun 10, 2011 | 11:36 PM
Adam86's Avatar
Already had my entire top end off so I went out the top. Tranny still attached too. Not a terrible job with the right tools. Just pull it out very very slowly to make sure you have everything disconnected and so you can adjust the tranny as needed as it comes out.
Old Jun 11, 2011 | 10:18 AM
-Q-'s Avatar
-Q-
Old Jun 11, 2011 | 10:36 AM
A.R. Shale Targa's Avatar
Q's thread is a definite MUST READ !!!!!!!
Old Jun 11, 2011 | 12:33 PM
Adam86's Avatar
Q I am pissed off that I didn't put as much time into my car as you did yours when the motor was out. You're car looks awesome.
Old Jun 11, 2011 | 12:40 PM
-Q-'s Avatar
-Q-
Thanks. It was a great experience, and I think everything turned out very well.
