4.8L Question????
Old Jun 9, 2011 | 10:33 AM
danielshane4's Avatar
Default 4.8L Question????
Ive been doing a little research and reading some forums and I had a question about a 4.8L. Would it be possible to bore the block to take an LS1 piston, and put something like a 383 stroker crank in it with 6.0 rods or some kind of set up like that? Just looking into building a high compression small block out of a tiny 4.8. Any suggestions or comments greatly appreciated!
Old Jun 9, 2011 | 10:37 AM
dodson55's Avatar
yes you can a 4.8 uses the same block as a 5.3 and people do it to 5.3 all the time
Old Jun 9, 2011 | 11:38 AM
Would there be any PTV clearance issues with a 4.00 in stroke with a 6.00 rod with stock cylinder heads?
Old Jun 9, 2011 | 11:41 AM
Jon@Texas-Speed's Avatar
More than likely an aftermarket piston is going to have a valve relief. Typically you won't have a PtV issue but it is something you always want to check. Also, you might look at a 6.125" rod length. That is a more common setup and there will be more pistons available.
Jon
Old Jun 9, 2011 | 11:51 AM
thanks for the tip, ill look into it, i was lookin into a cam setup like 230/224 .575/.563 111 LSA, what kind of valve relief should i be looking for or will the retailer be able to tell me when i look for my piston setup
Old Jun 9, 2011 | 01:07 PM
mark21742's Avatar
Call up Texas Speed, they should be able to get you just about anything you need....
You can get flat top, dome, or dished pistons with just about any size valve relief you need. If its not as common, you might just have to wait a week or two for the factory to custom make them for you....but I agree with Jon, if you go with a 6.125" rod you piston options will be better and probably cheaper
Old Jun 9, 2011 | 01:42 PM
okay thanks for the help, would it be worth the money for the power gain with the bored 4.8 and stroker set up with a cam or should I go a different route? im pretty stuck on the 4.8 block, just wanna be different from the 6.0 guys ha
Old Jun 9, 2011 | 02:49 PM
KCS's Avatar
KCS
Moderator
Do it. You can make pretty good power with a 4.8L based 383, but your cam choice seems a little odd. What heads, bolt ons, etc?
Old Jun 9, 2011 | 03:44 PM
mark21742's Avatar
I would think a standard split with these duration numbers would be better than the reverse split
Old Jun 10, 2011 | 01:55 PM
Ill be sportin the stock cylinder heads, i will probably have them ported and polished, and i thought the standard split was for forced induction applications, i really dont know what i need for a cam setup as far as the 383 arrangement, could yall throw out some suggestions about which cam would be best suited for that high compression im lookin for, i just want to squeeze as much power outta the 383 as i can. Thanks so much everyone
