Way to Determine My Static Compression??
Old Mar 2, 2004 | 12:38 PM
TeeKay's Avatar
smokemup, you have indeed taken care of ALL the details in your calculations! Great job.
spinmonster, most stock stroke crank/rod/piston combo's calculate 9.249" tall (3.622/2+6.098+1.340 = deck of +.001), that's what I was basing my quick calc's on. Also, most aftermarket pistons come in 3.905 bore diameter, so I have to assume that the block is honed for that bore. All-in-all, though you're right, there is a difference, but it's usually less that .1:1 (1 point) cr. Sorry, I thought that would be close enough for a good estimate.
Old Mar 2, 2004 | 12:39 PM
smokemup's Avatar
Originally Posted by SilverGhost
Thanks for you help, I like your site by the way, the calculator is pretty sweet..
Thanks.
Old Mar 4, 2004 | 01:34 PM
Spinmonster's Avatar
OK I'm a bit ****....lol
Old Mar 5, 2004 | 11:19 PM
TeeKay's Avatar
Not to worry, when you're right you're right!
Old Mar 6, 2004 | 07:57 AM
arron's Avatar
11.1-1 is what i come up with for your combo
