Texas Speed & Performance NEW WEBSITE!
If anybody else is running into the issue where you click into numerous categories and there are no parts showing, PLEASE let us know! We were finally able to duplicate the problem, and believe we have it fixed, but need your feedback if it is still happening to you!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old School Heavy
For SEO purposes consider creating subfolders for your parts and services categories. Having URLs that contain keywords for your most desirable searches is a crucial strategy. Using subfolders for your categories such as "parts" or "service" can help you achieve this and improve the overall keyword density of your site.
For example, your current site produces this URL for 98-02 F-body parts:
"http://www.texas-speed.com/c-7-98-02-camaro-firebird-v8.aspx"
This is good because it does contain the keywords Camaro, Firebird & 98-02, but here is how it could be much better with a sub folder:
"http://www.texas-speed.com/performance-parts/c-7-98-02-camaro-firebird-v8.aspx"
This is vastly superior because it will help you with search engine performance for searches like "camaro performance parts" or "02 camaro performance parts". This is called long-tail keyword strategy and it is very desirable because it gives you maximum visibility in searches to people who are actively seeking your specific services. It is also extremely beneficial because you will find it easier to get top search results for "camaro performance parts" than you would a more generic term like "camaro parts".
Even more superior might be something like:
"http://www.texas-speed.com/performance-parts/ls1-98-02-camaro-firebird-v8.aspx"
Now your url will help you with searches like: "ls1 perforamance parts". Your webmaster should be able to make these adjustments easily and there is no downside.
#34
http://www.texas-speed.com/s-4-sales-and-specials.aspx
Be sure to check in the "Sales and Specials" section for random sales! The cam packages, with select camshafts, are on sale currently!
__________________
#36
Restricted User
#40
We were down for a little bit over the weekend and then again yesterday morning early....but the changes we were making on the server are all done now and everything should be running fine.
__________________
