Quick starter question
Old Jun 15, 2011 | 03:54 PM
pairof69s's Avatar
Default Quick starter question
Fairly new to the Ls, doing a compression check on a LQ9 motor is on engine stand, how should I hook up the battery to the starter, gonna use a remote starter button also.
Old Jun 15, 2011 | 06:40 PM
chrisfrost's Avatar
Using battery cables hook the positive cable to the large lug/nut on the starter and the negative cable to a bolt on the block , then You're remote start button to the positive at the battery and the small lug/nut on the starter . Or to engage the starter without the starter button , just using a screw driver connect the 2 lugs/nuts on the starter making sure to not touch the screw driver to ground at the same time .
Old Jun 16, 2011 | 12:36 AM
01ssreda4's Avatar
Right, the starter grounds through the engine. So anywhere on the engine would be fine for the ground, preferably as close to the actual starter as you can get. The main + for the starter's power is the big stud on the solenoid. The small stud is the turn on for the solenoid, it needs a + to activate. So if both the big and little stud have 12v+ and the engine is grounded, the starter will turn over indefinitely as long as you hold that connection. The button would go inline with the small stud I'm sure, but I have never actually used one.
Old Jun 16, 2011 | 01:49 PM
pairof69s's Avatar
hey fellas I appreciate the feedback
