Decking a block
Old Jun 15, 2011 | 04:24 PM
kossuth's Avatar
Default Decking a block
How much can you safely take off a stock LS1 aluminum block deck?
Old Jun 15, 2011 | 04:38 PM
redz_02's Avatar
https://ls1tech.com/forums/generatio...liner-etc.html
Old Jun 16, 2011 | 05:12 PM
kossuth's Avatar
Well, that doesn't give me the specs I was looking for. Thanks though.
Old Jun 16, 2011 | 06:06 PM
smask04C5's Avatar
I've taken as much as .018 off the deck of an 1168 LS6 block. The decks are surprisingly level, front to back and side to side. I am building a '383' for my vette and I took .013 off the driver's side bank and .014 off passenger side to get pistons .006 out of the hole.
Old Jun 16, 2011 | 06:28 PM
kossuth's Avatar
Wow, that's a alot I would think... Any idea what your deck height was afterwards?
Old Jun 16, 2011 | 07:24 PM
smask04C5's Avatar
9.224 finished deck. Rods are 6.125 plus 1/2 stroke plus compression height should be 9.23 assembled rod length.
Old Jun 16, 2011 | 09:00 PM
kossuth's Avatar
Gotcha. So your motor was about 9.24" from the start "roughly" Thank you. Here's what I am doing. I'm trying to refresh a motor using mostly stock components. Deck is alittle rough gonna need about .005 removed to clean it up. After doing about 4 hours of looking I ran across this. http://www.ls1engine.com/tech/ls1-en...arances-specs/ So I'm hoping this block is on the + side (especially on the damaged side) the block is + some material.
Old Jun 17, 2011 | 07:16 PM
smask04C5's Avatar
If you are trying to fix with stock parts, remember that the stock piston can be proud of the bore by .010-.012 @TDC. Just make sure you make corresponding changes to quench. Tighter quench reduces possibility of detonation. If you end up .010 proud on pistons, I'd use a .045 Cometic MLS gasket.
 Michael S. Palmer
Old Jun 18, 2011 | 02:59 PM
bww3588's Avatar
i have a 9.2182 finished deck on a 6.0 iron block.
Old Jun 19, 2011 | 08:40 PM
kossuth's Avatar
10-4, gotta see what the shop says on the block. Probiably will be a few days yet though. Thanks for your guys help.
